Ana içeriğe geç
Framework Laptop 12 Pre-built Quick Start Guide
    1. Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: adım 1, 2 resimden 1. Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: adım 1, 2 resimden 2.
      • Unbox your Framework Laptop and make sure you've received all the items:
      • Framework Laptop 12
      • Framework Screwdriver
      • Expansion Cards you selected during purchase
      • Framework Power Adapter, USB-C Cable, and AC Cable
      FixBot'a Sor
      Yorum Ekle
    2. Framework Laptop 12 Pre-built Quick Start Guide, Set your laptop on a clean surface: adım 2, 1 resimden 1.
      • Set your Framework Laptop face-down on a clean work surface.
      FixBot'a Sor
      Yorum Ekle
    3. Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: adım 3, 3 resimden 1. Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: adım 3, 3 resimden 2. Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: adım 3, 3 resimden 3.
      • Slide an Expansion Card into the Expansion Card slot.
      • All official Expansion Cards work fully in all slots, so you can install them however you wish!
      • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click in place, and the front edge should be flush with the laptop.
      • Repeat the procedure with the remaining expansion cards.
      FixBot'a Sor
      Yorum Ekle
    4. Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: adım 4, 2 resimden 1. Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: adım 4, 2 resimden 2.
      • If there's a red bar showing under each Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots help keep the cards in place when you unplug cables from them.
      FixBot'a Sor
      Yorum Ekle
    5. Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: adım 5, 3 resimden 1. Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: adım 5, 3 resimden 2. Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: adım 5, 3 resimden 3.
      • Plug the AC Cable into the Power Adapter.
      • Plug the USB-C Cable into the Power Adapter.
      • You can plug either end of the USB-C cable into the adapter.
      • Plug the AC Cable into a power outlet.
      FixBot'a Sor
      Yorum Ekle
    6. Framework Laptop 12 Pre-built Quick Start Guide, Plug in the laptop: adım 6, 1 resimden 1.
      • Your Framework Laptop ships in shipping mode, where the battery is disabled until you plug the laptop in for the first time.
      • Plug the USB-C cable into any USB-C port on your laptop.
      FixBot'a Sor
      Yorum Ekle
    7. Framework Laptop 12 Pre-built Quick Start Guide, Turn on the laptop: adım 7, 1 resimden 1.
      • Your Framework Laptop is ready for use! Open the lid and press the power button along the right edge of the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For drivers, firmware, and software updates, check out this page.
If you need help, contact Framework support.
Arthur Shi
344.562 İtibar
915 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
42.409 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 496
