Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Attach the extendable footrest bar to the front frame at the desired height
Make sure the two bolt holes on the footrest bar line up with two of the holes on the front frame
Push a flat head bolt through the hole in the frame.
Use the 10mm wrench to secure the nut on the other side of the bolt
Twist the 10mm wrench counter-clockwise to tighten the nut
Attach the three other flat-head bolts and nuts to the remaining holes by using the 10mm wrench
Attach the footrest to the footrest bar with the bottom of the footrest pointing upwards
Match the footrest wedges up with the holes and push 4 small bolts through the holes
Tighten the nuts onto the bolts using the 10mm wrench
Flip the footrest back over and the footrest is now ready for use
To change the footrest's position, repeat the previous steps but move the footrest bar to the preferred position by lining up the footrest bar with the holes on the sides of the frame
Bir başkası bu kılavuzu tamamladı.
