Ana içeriğe geç
Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement
Neye ihtiyacın var
  1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: adım 1, 2 resimden 1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: adım 1, 2 resimden 2.
    • Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
    • With the other hand use the 19mm crescent wrench to hold the nut in place
    • While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
    • Remove the wheel from the axle
  2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 2, 2 resimden 1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 2, 2 resimden 2.
    • Unscrew the nut holding the bolt and wheel together using your hands.
    • It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
    • Repeat step on other wheel
    • Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
  3. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 3, 2 resimden 1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 3, 2 resimden 2.
    • Locate the two baseplates on the back of the wheelchair holding the axle in place
  4. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 4, 3 resimden 1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 4, 3 resimden 2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 4, 3 resimden 3.
    • Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
    • Repeat above step on second bolt
    • Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
  5. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 5, 3 resimden 1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 5, 3 resimden 2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: adım 5, 3 resimden 3.
    • Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
    • The axle should come off easily
    • Slide the baseplates off of the axle
Sonuç
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Mike Sevilla
348 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G7
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,548
