Ana içeriğe geç
Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement
Neye ihtiyacın var
  1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: adım 1, 2 resimden 1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheels from Frame: adım 1, 2 resimden 2.
    • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame.
    • Remove the wheel from the small steel frame.
  2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: adım 2, 3 resimden 1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: adım 2, 3 resimden 2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Unfasten Castor Wheel from Wheel Fork: adım 2, 3 resimden 3.
    • Hold the bolt that connects the wheel to the fork with pliers.
    • This keeps the bolt through the wheel from rotating.
    • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt.
  3. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: adım 3, 3 resimden 1. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: adım 3, 3 resimden 2. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Castor Wheel from Wheel Fork: adım 3, 3 resimden 3.
    • Flip wheel over and remove the bolt.
    • Remove the castor wheel.
  4. Free Wheelchair Mission GEN 1 Wheelchair Castor Wheel Replacement, Remove Obstructing Debris: adım 4, 1 resimden 1.
    • Check for and remove any debris from the wheel or wheel axel that may be obstructing motion.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alyssa Chaney
49 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 üyesi
CPSU-MANESS-S13S14G7
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 1,507
