Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
We will start by removing the wheel and removing any debris that may be obstructing motion, and then reattach the wheel to the axle of the chair.
Familiarize yourself with the tools required for this guide by reading through the Free Wheelchair Mission Tools Maintenance Guide.
Neye ihtiyacın var
Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame
Remove the wheel from the small steel frame
Hold the bolt that connects the wheel to the fork with pliers
Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt
Flip wheel over and remove the bolt
Remove the castor wheel
Check for and remove any debris from the wheel or wheel axle that may be obstructing motion of the wheel
Bir başkası bu kılavuzu tamamladı.
