Giriş
This is a guide for replacing the battery for the Marshall Kilburn Portable Bluetooth Speaker. If the internal battery is broken or worn out, you can replace it with a new one.
Neye ihtiyacın var
Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
Bir Yorum
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
