Ana içeriğe geç
Frigidaire FFPE45B2QM Refrigerator Door Replacement
Neye ihtiyacın var
  1. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Broken Hinge: adım 1, 1 resimden 1.
    • Carefully pop off the cover using a spudger or other opening tool.
  2. Frigidaire FFPE45B2QM Refrigerator Door Replacement: adım 2, 1 resimden 1.
    • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  3. Frigidaire FFPE45B2QM Refrigerator Door Replacement: adım 3, 2 resimden 1. Frigidaire FFPE45B2QM Refrigerator Door Replacement: adım 3, 2 resimden 2.
    • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  4. Frigidaire FFPE45B2QM Refrigerator Door Replacement, Refrigerator Door: adım 4, 1 resimden 1.
    • Remove the door by slowly lifting straight up, put the door off to the side.
  5. Frigidaire FFPE45B2QM Refrigerator Door Replacement: adım 5, 1 resimden 1.
    • Get a new, non-damaged door.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Peterluchini
556 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 üyesi
UMASSD-BHUSAL-F15S1G2
3 Üyeler
Bir Yorum
So this is a 4.5 cubic foot mini-refrigerator. I suppose the door was damaged in moving the refrigerator - maybe dropped because it has a weight of 58 pounds.
doctordon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,443
