Ana içeriğe geç
Frigidaire Gallery Water Filter Replacement
Neye ihtiyacın var
  1. Frigidaire Gallery Water Filter Replacement, Water Filter: adım 1, 1 resimden 1.
    • Locate the water filter in the back of the interior compartment.
    • It looks like a long white cylinder.
  2. Frigidaire Gallery Water Filter Replacement: adım 2, 2 resimden 1. Frigidaire Gallery Water Filter Replacement: adım 2, 2 resimden 2.
    • Push back on the compartment to remove the filter.
    • The filter will then pop out.
    • Remove the used filter and discard it.
  3. Frigidaire Gallery Water Filter Replacement: adım 3, 3 resimden 1. Frigidaire Gallery Water Filter Replacement: adım 3, 3 resimden 2. Frigidaire Gallery Water Filter Replacement: adım 3, 3 resimden 3.
    • Unwrap the replacement filter from its packaging.
    • Insert the replacement filter into the water filter housing.
    • You should hear an audible click when the filter is in place.
  4. Frigidaire Gallery Water Filter Replacement: adım 4, 1 resimden 1.
    • Once the filter is in place, close the refrigerator door and press the water button on the freezer side.
    • Run the water for 2-3 minutes, or run approximately 2-3 gallons of water through the system to flush the filter with running water.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 208
Her zaman: 5,038
