Ana içeriğe geç
Front Panel Assembly Replacement
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
    1. Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
      • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
      • You will want to heat up the screen edges with the iOpener to help facilitate removal.
      FixBot'a Sor
      Yorum Ekle
    2. Front Panel Assembly Replacement: adım 2, 1 resimden 1.
      • Remove the button cover by lifting the cover away from the tablet.
      FixBot'a Sor
      Yorum Ekle
    3. Front Panel Assembly Replacement: adım 3, 1 resimden 1.
      • Using the Torx screwdriver, remove the 4mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Front Panel Assembly Replacement: adım 4, 1 resimden 1.
      • With the Torx screwdriver, remove the two 5mm screws.
      FixBot'a Sor
      Yorum Ekle
    5. Front Panel Assembly Replacement: adım 5, 2 resimden 1. Front Panel Assembly Replacement: adım 5, 2 resimden 2.
      • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
      • With the Torx screwdriver, remove the two 4mm screws.
      FixBot'a Sor
      Yorum Ekle
    6. Front Panel Assembly Replacement: adım 6, 1 resimden 1.
      • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
      FixBot'a Sor
      Yorum Ekle
    7. Front Panel Assembly Replacement: adım 7, 2 resimden 1. Front Panel Assembly Replacement: adım 7, 2 resimden 2.
      • Ribbon cables are very sensitive and prone to breaking
      • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
      • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carlos Salas
194 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G6
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 276
