Ana içeriğe geç
Fugoo Tough Speaker Replacement
Neye ihtiyacın var
  1. Fugoo  Tough Speaker Replacement, Speaker: adım 1, 3 resimden 1. Fugoo  Tough Speaker Replacement, Speaker: adım 1, 3 resimden 2. Fugoo  Tough Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Begin by unscrewing the four 10.72mm corner screws using the Hex 2.0 screwdriver.
    • Using the Hex 1.5 screwdriver, remove the remaining six 5.79mm screws on the front of the speaker.
    • Pull the front part of shell away from the back part of shell.
  2. Fugoo  Tough Speaker Replacement: adım 2, 3 resimden 1. Fugoo  Tough Speaker Replacement: adım 2, 3 resimden 2. Fugoo  Tough Speaker Replacement: adım 2, 3 resimden 3.
    • Change to the Hex 1.3 head. Remove all 4-5.57mm screws on both speaker covers.
    • Pull on the speaker covers to remove them.
    • Rotate to side the speaker that has the charging port. Remove the 4-5.57mm screws of the facing you.
    • Rotate the speaker 180 degrees and then remove 4-5.57 screws on the side speaker that has the power/bluetooth buttons
  3. Fugoo  Tough Speaker Replacement: adım 3, 3 resimden 1. Fugoo  Tough Speaker Replacement: adım 3, 3 resimden 2. Fugoo  Tough Speaker Replacement: adım 3, 3 resimden 3.
    • Have back of speaker facing you, remove 5-12.70mm screws using 1/16 flat head screwdriver.
    • Using the plastic opening tool you will be able to wedge back face of speaker off.
  4. Fugoo  Tough Speaker Replacement: adım 4, 2 resimden 1. Fugoo  Tough Speaker Replacement: adım 4, 2 resimden 2.
    • The circuit board will be revealed, you will notice the various individual speaker connections to the circuit board.
    • Remove black "clip" from the circuit board. Using the T9 screwdriver head remove the 2-7.20mm screws, and remove the speaker from the body of the device
  5. Fugoo  Tough Speaker Replacement: adım 5, 1 resimden 1.
    • At this point, the next step would be to replace the speaker.
  6. Fugoo  Tough Speaker Replacement: adım 6, 1 resimden 1.
    • Undo the clips that are now exposed inside of the speaker. The colors of these clips are white, red, blue.
    • Once the clips are undone, you can freely remove and replace the corresponding speaker within the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 452
