Giriş
In this replacement guide, we will be showing the consumer how to correctly replace the inner speaker of the device.
Neye ihtiyacın var
Begin by unscrewing the four 10.72mm corner screws using the Hex 2.0 screwdriver.
Using the Hex 1.5 screwdriver, remove the remaining six 5.79mm screws on the front of the speaker.
Pull the front part of shell away from the back part of shell.
Change to the Hex 1.3 head. Remove all 4-5.57mm screws on both speaker covers.
Pull on the speaker covers to remove them.
Rotate to side the speaker that has the charging port. Remove the 4-5.57mm screws of the facing you.
Rotate the speaker 180 degrees and then remove 4-5.57 screws on the side speaker that has the power/bluetooth buttons
