Ana içeriğe geç
Fugoo Tough XL Case Replacement
Neye ihtiyacın var
  1. Fugoo Tough XL Case Replacement, Case: adım 1, 1 resimden 1.
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Fugoo Tough XL Case Replacement: adım 2, 2 resimden 1. Fugoo Tough XL Case Replacement: adım 2, 2 resimden 2.
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
    FixBot'a Sor
    Yorum Ekle
  3. Fugoo Tough XL Case Replacement: adım 3, 2 resimden 1. Fugoo Tough XL Case Replacement: adım 3, 2 resimden 2.
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Fugoo Tough XL Case Replacement: adım 4, 3 resimden 1. Fugoo Tough XL Case Replacement: adım 4, 3 resimden 2. Fugoo Tough XL Case Replacement: adım 4, 3 resimden 3.
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
    FixBot'a Sor
    Yorum Ekle
  5. Fugoo Tough XL Case Replacement: adım 5, 1 resimden 1.
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abdul
527 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,161
