Giriş
Use this guide to remove and replace the motherboard.
Neye ihtiyacın var
Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
Carefully untangle the wires that connect the speaker to the motherboard.
Bir başkası bu kılavuzu tamamladı.
7 Yorum
I would like to know where you purchased a fugoo tough or fugoo tough xl motherboard. Thanks you!!
Fugoo Tough XL Motherboard donde la puedo conseguir i que esta costando o que vale muchas gracias
Hi, I just opened my e-mail and this half information Ifixit was there. Wow, I spent weeks researching to find a motherboard. I called Fugoo and they assisted me with the major difficult project. ITs so simple to disassemble. You unscrew it and open it up. Very well built and engineered Bluetooth Speaker. MORE INFO NEXT COMMENT
change the battery just buy a similar battery and swap out the plugs. Very simple too. All I wanted was original though. The Fugoo speaker is awesome and the best. There customer support is perfect. Although, my only problem was with half information given and the details left out. For example, HOW TO REPLACE BATTERY.. The %#*@ instructions are the same as yours. Its how to take it apart. SO SIMPLE. Did you forget to tell everyone how to get the battery or how to modify one, because you can only get them in china and good luck its impossible. MORE INFO NEXT COMMENT
Amazon has them and the Harmon Kardon is a good replacement ($12)you have to swap plugs is all. And you mister your video is not how to replace a motherboard. Its how to take it apart. then the end. Where in the fxxk you find one is my question, because you did not even show a picture of the new one and where to get it or a picture of it installed.
