Ana içeriğe geç
Fugoo Tough XL Speaker Replacement
Neye ihtiyacın var
  1. Fugoo Tough XL Speaker Replacement, Case: adım 1, 1 resimden 1.
    • Remove the four 3 mm screws located in each corner using a 3 mm Hex screwdriver.
  2. Fugoo Tough XL Speaker Replacement: adım 2, 2 resimden 1. Fugoo Tough XL Speaker Replacement: adım 2, 2 resimden 2.
    • Gently pull up and off the outer casing.
    • Do not feel afraid to use a bit of force if necessary.
  3. Fugoo Tough XL Speaker Replacement: adım 3, 2 resimden 1. Fugoo Tough XL Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the internal device from the outer casing.
    • Remove the four 12 mm screws on each corner using a T10 Torx screwdriver.
    • Remove the eight 6 mm screws on the top and bottom using a T10 Torx screwdriver.
  4. Fugoo Tough XL Speaker Replacement: adım 4, 3 resimden 1. Fugoo Tough XL Speaker Replacement: adım 4, 3 resimden 2. Fugoo Tough XL Speaker Replacement: adım 4, 3 resimden 3.
    • Use your hands to gently remove the side plates.
    • Use an opening tool to pry off the back plate with the Fugoo trademark.
  5. Fugoo Tough XL Speaker Replacement: adım 5, 1 resimden 1.
    • Slowly pull the front casing from the back casing. Avoid putting any tension on the connected cables.
    • Separate the two slowly and consistently to avoid damaging the speaker cables.
  6. Fugoo Tough XL Speaker Replacement, Speaker: adım 6, 2 resimden 1. Fugoo Tough XL Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Carefully untangle the wires that are connected from the speaker to the motherboard.
    • Using a tweezer, pull downwards on the base of each red speaker connector to remove them from the motherboard.
  7. Fugoo Tough XL Speaker Replacement: adım 7, 3 resimden 1. Fugoo Tough XL Speaker Replacement: adım 7, 3 resimden 2. Fugoo Tough XL Speaker Replacement: adım 7, 3 resimden 3.
    • Use a #3 Hex screwdriver to unscrew all six 3mm screws."
    • While holding the case with one hand, pull up on the speaker you wish to replace.
Sonuç
Abdul
527 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G1, Hoffman Spring 2017 USF Tampa, Team S19-G1, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 984
