Ana içeriğe geç
FujiFilm FinePix A340 Flash Unit Replacement
Neye ihtiyacın var
  1. FujiFilm FinePix A340 Flash Unit Replacement, Outer Case: adım 1, 1 resimden 1.
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 Flash Unit Replacement: adım 2, 3 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 2, 3 resimden 2. FujiFilm FinePix A340 Flash Unit Replacement: adım 2, 3 resimden 3.
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 Flash Unit Replacement: adım 3, 2 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 3, 2 resimden 2.
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 Flash Unit Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 Flash Unit Replacement: adım 5, 1 resimden 1.
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 Flash Unit Replacement: adım 6, 1 resimden 1.
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 Flash Unit Replacement: adım 7, 1 resimden 1.
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 Flash Unit Replacement: adım 8, 1 resimden 1.
    • Now that everything has been disconnected from the board, remove LCD screen.
  9. FujiFilm FinePix A340 Flash Unit Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the two screws holding the circuit board down.
  10. FujiFilm FinePix A340 Flash Unit Replacement: adım 10, 2 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 10, 2 resimden 2.
    • Remove black sticky tape from circuit board and camera case.
  11. FujiFilm FinePix A340 Flash Unit Replacement: adım 11, 2 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 11, 2 resimden 2.
    • Gently pull the circuit board away from the front side of the camera.
    • Be careful when removing assembly as to not break any solder leads or damage lens assembly.
  12. FujiFilm FinePix A340 Flash Unit Replacement: adım 12, 2 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 12, 2 resimden 2.
    • Remove the logic board by pulling straight away from assembly.
  13. FujiFilm FinePix A340 Flash Unit Replacement, Flash Unit: adım 13, 1 resimden 1.
    • Locate the flash unit of the camera. It includes the camera's flash and a capacitor.
  14. FujiFilm FinePix A340 Flash Unit Replacement: adım 14, 2 resimden 1. FujiFilm FinePix A340 Flash Unit Replacement: adım 14, 2 resimden 2.
    • Unsolder the flash unit at it's three points.
    • Be careful not to damage the circuit board or surrounding parts with the solder iron.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cody
47 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G11
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 3,895
