Ana içeriğe geç
FujiFilm FinePix A340 LCD Screen Replacement
Neye ihtiyacın var
  1. FujiFilm FinePix A340 LCD Screen Replacement, Outer Case: adım 1, 1 resimden 1.
    • To prevent the danger of electric shock, remove the batteries before continuing to the next steps.
    • Slide the battery cover to the side to release the batteries.
  2. FujiFilm FinePix A340 LCD Screen Replacement: adım 2, 3 resimden 1. FujiFilm FinePix A340 LCD Screen Replacement: adım 2, 3 resimden 2. FujiFilm FinePix A340 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Remove five screws from the camera casing using a tri-point Y0 screwdriver.
  3. FujiFilm FinePix A340 LCD Screen Replacement: adım 3, 2 resimden 1. FujiFilm FinePix A340 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Grab the case with your hands and slowly pull back the outer casing.
  4. FujiFilm FinePix A340 LCD Screen Replacement, LCD Screen: adım 4, 1 resimden 1.
    • Locate the LCD screen and anchoring screw.
    • Remove screw.
  5. FujiFilm FinePix A340 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Carefully pull the LCD screen away from the board it is connected to.
  6. FujiFilm FinePix A340 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Push both blue switches away from the holding device to unleach lcd ribbon.
    • Be careful when removing ribbon. If you damage it, you will need to replace it as well.
  7. FujiFilm FinePix A340 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Carefully detach the ribbon from where it was connected by the blue pins.
  8. FujiFilm FinePix A340 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Now that everything has been disconnected from the board, remove LCD screen.
Sonuç
Cody
47 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-11, Maness Spring 2010 Cal Poly, Team 7-11, Maness Spring 2010 üyesi
CPSU-MANESS-S10S7G11
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 6,095
