Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Slide the battery cover to the side to release the batteries.
Remove five screws from the camera casing using a tri-point Y0 screwdriver.
Grab the case with your hands and slowly pull back the outer casing.
Locate the LCD screen and anchoring screw.
Remove screw.
Carefully pull the LCD screen away from the board it is connected to.
Push both blue switches away from the holding device to unleach lcd ribbon.
Carefully detach the ribbon from where it was connected by the blue pins.
Now that everything has been disconnected from the board, remove LCD screen.
Remove black sticky tape from circuit board and camera case.
Gently pull the circuit board away from the front side of the camera.
Remove the logic board by pulling straight away from assembly.
