Ana içeriğe geç
FujiFilm FinePix S4500 LCD Replacement
Neye ihtiyacın var
  1. FujiFilm FinePix S4500 LCD Replacement, LCD: adım 1, 1 resimden 1.
    • Remove the two 3.5 mm Phillips #1 screws in these positions on the left side of the camera with a screwdriver.
  2. FujiFilm FinePix S4500 LCD Replacement: adım 2, 1 resimden 1.
    • Remove the three 3.5 mm Phillips #1 screws in these locations on the bottom of the camera with a screwdriver.
  3. FujiFilm FinePix S4500 LCD Replacement: adım 3, 1 resimden 1.
    • Remove the four 3.5 mm Phillips #1 screws in these positions on the right side of the camera with a screwdriver.
  4. FujiFilm FinePix S4500 LCD Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to separate the back panel from the camera on the left side.
  5. FujiFilm FinePix S4500 LCD Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to separate the back panel from the camera on the bottom.
  6. FujiFilm FinePix S4500 LCD Replacement: adım 6, 2 resimden 1. FujiFilm FinePix S4500 LCD Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to separate the back panel from the camera on the left side, then remove the back panel from the camera.
  7. FujiFilm FinePix S4500 LCD Replacement: adım 7, 1 resimden 1.
    • Use a plastic opening tool to separate the LCD screen from the camera.
  8. FujiFilm FinePix S4500 LCD Replacement: adım 8, 2 resimden 1. FujiFilm FinePix S4500 LCD Replacement: adım 8, 2 resimden 2.
    • Flip up the black tab holding the LCD ribbon wire in place and remove wire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vicente Rios
708 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-4, Banghart Winter 2017 Cal Poly, Team 9-4, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G4
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 590
