Ana içeriğe geç
FujiFilm FinePix XP10SE Front Cover Replacement
Neye ihtiyacın var
  1. FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: adım 1, 3 resimden 1. FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: adım 1, 3 resimden 2. FujiFilm FinePix XP10SE Front Cover Replacement, Front Cover: adım 1, 3 resimden 3.
    • Use a screwdriver to remove the four screws from the top and bottom of the camera. Remove the screws securing the lanyard as well.
    • Use a T5 Torx bit to secure the exterior decorative cover of the device.
  2. FujiFilm FinePix XP10SE Front Cover Replacement: adım 2, 2 resimden 1. FujiFilm FinePix XP10SE Front Cover Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to detach the case.
  3. FujiFilm FinePix XP10SE Front Cover Replacement: adım 3, 2 resimden 1. FujiFilm FinePix XP10SE Front Cover Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to cautiously pry the casing off of the camera.
  4. FujiFilm FinePix XP10SE Front Cover Replacement: adım 4, 3 resimden 1. FujiFilm FinePix XP10SE Front Cover Replacement: adım 4, 3 resimden 2. FujiFilm FinePix XP10SE Front Cover Replacement: adım 4, 3 resimden 3.
    • Carefully slide the case to the left. Avoid cracking the case on the lens.
Sonuç
Bryan
598 İtibar
5 adet Kılavuz yazıldı
Ekip
Pasco Hernando, Team 5-1, Prince Winter 2015 Pasco Hernando, Team 5-1, Prince Winter 2015 üyesi
PHSC-PRINCE-W15S5G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 148
