Giriş
Although a non-functioning screen would be hard to manage with this device, replacing the LCD screen is relatively easy.
Neye ihtiyacın var
Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
Unlatch the four clasps located on each side of the camera by hand.
The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm FinePix XP50 Battery Replacement for instructions.
Take the spudger and wedge it in between the screen and the frame.
Slowly make your way around the screen with the spudger just enough to separate the screen from the frame.
