Ana içeriğe geç
Fujifilm FinePix Z90 Lens cover/case Replacement
Neye ihtiyacın var
  1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: adım 1, 2 resimden 1. Fujifilm  FinePix Z90 Lens cover/case Replacement, Lens cover/case: adım 1, 2 resimden 2.
    • Use a small #000 Phillips screwdriver to take the screws out. Keep all the screws in a container and the two different types separate.
    • Remove the two screws on the right side.On the same side there is USB connector, open that little door and unscrew the little screw inside of it.
  2. Fujifilm  FinePix Z90 Lens cover/case Replacement: adım 2, 2 resimden 1. Fujifilm  FinePix Z90 Lens cover/case Replacement: adım 2, 2 resimden 2.
    • Take the two screws on the left side and the two screws on the bottom of the camera.
  3. Fujifilm  FinePix Z90 Lens cover/case Replacement: adım 3, 2 resimden 1. Fujifilm  FinePix Z90 Lens cover/case Replacement: adım 3, 2 resimden 2.
    • By now you will have the front case and the back case separated from each other.
Sonuç
Sam Clark
301 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Bhusal Fall 2015 UMass Dartmouth, Team 1-6, Bhusal Fall 2015 üyesi
UMASSD-BHUSAL-F15S1G6
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 250
