Ana içeriğe geç
Fujifilm Endeavor 100ix Battery Door Replacement
Neye ihtiyacın var
  1. Fujifilm Endeavor 100ix Battery Door Replacement, Battery Door: adım 1, 1 resimden 1.
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Fujifilm Endeavor 100ix Battery Door Replacement: adım 2, 1 resimden 1.
    • Locate the battery door.
  3. Fujifilm Endeavor 100ix Battery Door Replacement: adım 3, 1 resimden 1.
    • Locate the latch on the battery door.
    • Use your finger pry to it open where it says "BATT."
  4. Fujifilm Endeavor 100ix Battery Door Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the camera by pulling the battery door outward.
  5. Fujifilm Endeavor 100ix Battery Door Replacement: adım 5, 1 resimden 1.
    • Locate and remove three black 3.80mm screws on the back of the black casing with the Phillips #00 screwdriver.
  6. Fujifilm Endeavor 100ix Battery Door Replacement: adım 6, 1 resimden 1.
    • Squeeze the camera placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  7. Fujifilm Endeavor 100ix Battery Door Replacement: adım 7, 2 resimden 1. Fujifilm Endeavor 100ix Battery Door Replacement: adım 7, 2 resimden 2.
    • Locate and remove the 3.80mm screw that holds the plastic strip to the camera body with a Phillips #00 screwdriver.
    • The plastic strip will now come off the camera body.
Sonuç
Eric Nicolai
679 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 üyesi
CPSU-FORTE-W11S13G5
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 14
Her zaman: 1,874
