Ana içeriğe geç
Fujifilm Fine S1800 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm Fine S1800 LCD Screen Replacement, Back Cover Assembly: adım 1, 1 resimden 1.
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Fine S1800 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Fine S1800 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Fine S1800 LCD Screen Replacement: adım 4, 2 resimden 1. Fujifilm Fine S1800 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 1. Fujifilm Fine S1800 LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 2.
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Fine S1800 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Fine S1800 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
Sonuç
Ryan Rockford
618 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-6, Eyestone Spring 2017 USF Tampa, Team 8-6, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G6
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 592
