Ana içeriğe geç
Fujifilm FinePix 4700 Zoom Back Cover Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. Fujifilm FinePix 4700 Zoom Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the Phillips #00 screwdriver to remove the 7 screws on the sides of the camera:
    • Four 3.95mm Phillips screws located on the bottom of the camera
    • Two 3.95mm Phillips screws located on the right side of the camera
    • One 3.95mm Phillips screw located on the left side of the camera
  2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 2, 1 resimden 1.
    • Slide open the battery compartment cover with your thumb.
  3. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 3, 3 resimden 1. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 3, 3 resimden 2. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 3, 3 resimden 3.
    • Wedge the edge of the spudger between the front and back case, near the corner of the flash.
    • Carefully run the spudger along the right edge of the camera, creating an opening.
    • Insert the spudger into the left side of the camera, above the screwhole. Then carefully run it along this edge.
  4. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 4, 2 resimden 1. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 4, 2 resimden 2.
    • Watch out for the orange ribbon that is still attached to the back cover when you lift it up. It is very delicate and might rip.
    • Slowly lift the back cover straight up, lightly jiggling it if necessary.
    • Remove the battery compartment cover.
  5. Fujifilm FinePix 4700 Zoom Back Cover Replacement: adım 5, 1 resimden 1.
    • Gently insert the spudger under the clip holding the orange ribbon. The clip should lift up and the ribbon will slide out.
    • This step will free the back cover from the rest of the camera.
Sonuç
Sarthak Patel
10 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G8
5 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,135
