Ana içeriğe geç
Fujifilm FinePix A350 Battery Contact Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: adım 1, 3 resimden 1. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: adım 1, 3 resimden 2. Fujifilm FinePix A350 Battery Contact Replacement, Batteries: adım 1, 3 resimden 3.
    • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
    • Using your thumb, slide the hatch away from the center of the camera.
    • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
  2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: adım 2, 3 resimden 1. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: adım 2, 3 resimden 2. Fujifilm FinePix A350 Battery Contact Replacement, Battery Contact: adım 2, 3 resimden 3.
    • On the underside of the battery hatch, locate the single 3.0 mm screw connecting the battery contact to the hatch. Remove it using a Phillips screwdriver with a #0 bit.
    • Lift the contact from the end where the screw was located and pull away from the hatch to remove it.
Sonuç
Jaxon Cramer
1.045 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G4
4 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
It turned on after lifting up contact. Thank you, but we figured it out as I started to begin reading.
David Justin Laylon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 465
