Ana içeriğe geç
Fujifilm FinePix A350 Memory Card Replacement
    1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: adım 1, 3 resimden 1. Fujifilm FinePix A350 Memory Card Replacement, Batteries: adım 1, 3 resimden 2. Fujifilm FinePix A350 Memory Card Replacement, Batteries: adım 1, 3 resimden 3.
      • Locate the battery hatch on the bottom side of the camera, opposite the side with the power button.
      • Using your thumb, slide the hatch away from the center of the camera.
      • Flip the hatch toward yourself to open it. The batteries are spring-loaded; once the hatch is open, they will protrude far enough to be removed by hand.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: adım 2, 3 resimden 1. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: adım 2, 3 resimden 2. Fujifilm FinePix A350 Memory Card Replacement, Memory Card: adım 2, 3 resimden 3.
      • Locate the memory card in the long, thin slot above the battery compartment.
      • Using your thumb, push the memory card farther into the camera.
      • The memory card is spring-loaded and will pop out of the camera far enough to be removed by hand.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jaxon Cramer
1.045 İtibar
9 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-4, Benson Spring 2016 Clemson, Team 6-4, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G4
4 Üyeler
17 adet Kılavuz yazıldı
1Rehber Yorum
Bonjour monsieur,
Pourquoi je ‘arrive plus à voir les photos je peu les prendre mais pas les voir “erreurs écriture “
Carte sd vierge.
Merci pour votre aide et bonne soirée
oli.ber - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 2,269
