Ana içeriğe geç
Fujifilm FinePix HS30EXR Motherboard Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix HS30EXR Motherboard Replacement, Frame: adım 1, 1 resimden 1.
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 2, 1 resimden 1.
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 3, 1 resimden 1.
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 4, 1 resimden 1.
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 5, 1 resimden 1.
  6. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 6, 1 resimden 1.
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 7, 2 resimden 1. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 7, 2 resimden 2.
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 9, 1 resimden 1.
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 10, 1 resimden 1.
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 11, 1 resimden 1.
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 12, 1 resimden 1.
  13. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 13, 1 resimden 1.
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 14, 1 resimden 1.
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Scouten
886 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G2, Williams Fall 2018 Baylor, Team S1-G2, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G2
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
have you instructions to remove power on and selector assembly?
renato.ciccone - Yanıt
have you istructions to remove the poweron switch asm. for the hs30exr?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 1,540
