Ana içeriğe geç
Fujifilm FinePix S1 EVF/LCD Button Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: adım 1, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: adım 1, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement, Back Camera Body: adım 1, 3 resimden 3.
    • Remove the 7 screws on the perimeter of the camera body.
  2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 2, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 2, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 2, 3 resimden 3.
    • Remove the flash accessory cap.
    • Remove the spacer covering the screws under the flash accessory cap.
  3. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 3, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 3, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 3, 3 resimden 3.
    • Remove the 4 screws from the inside of the flash accessory slot.
    • Pull off the flash accessory slot.
  4. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 4, 2 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 4, 2 resimden 2.
    • Remove the screw from LCD Screen hinge cover.
    • Remove the LCD Screen hinge cover.
  5. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 5, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 5, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 5, 3 resimden 3.
    • Remove the 3 screws located on the LCD screen hinge.
    • Remove the caps from both ends of the LCD screen hinge by lifting them off.
  6. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 6, 1 resimden 1.
    • Remove the 2 screws from under the LCD hinge caps.
  7. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 7, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 7, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 7, 3 resimden 3.
    • Pry apart the back body from the rest of the camera.
  8. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 8, 2 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 8, 2 resimden 2.
    • Carefully pull the back body off of the camera.
    • Make sure to not yank off the connections from the body to the motherboard.
  9. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 9, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 9, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 9, 3 resimden 3.
    • Use a spudger to lift up on the tab, releasing the yellow wire strip.
    • Use a spudger to lift up on the side tab, releasing the blue wire connection.
  10. Fujifilm FinePix S1 EVF/LCD Button Replacement, EVF/LCD Button Cover: adım 10, 1 resimden 1.
    • Remove 2 screws from back of EVF/LCD button.
  11. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 11, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 11, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 11, 3 resimden 3.
    • Pull EVF/LCD button frame out from the camera casing.
  12. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 12, 3 resimden 1. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 12, 3 resimden 2. Fujifilm FinePix S1 EVF/LCD Button Replacement: adım 12, 3 resimden 3.
    • Pull button cover off of the button frame.
Sonuç
Brandon Benavente
677 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Sullivan Spring 2016 USF Tampa, Team 3-6, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G6
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,297
