Ana içeriğe geç
Fujifilm FinePix S1 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Fujifilm FinePix S1 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Remove the 4 screws surrounding the LCD screen.
  2. Fujifilm FinePix S1 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to remove the casing on the hinge of the LCD screen.
  3. Fujifilm FinePix S1 LCD Screen Replacement: adım 3, 2 resimden 1. Fujifilm FinePix S1 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to pry apart the LCD screen casing and remove the casing.
  4. Fujifilm FinePix S1 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the 2 screws located on the inner corners of the inside of the LCD screen.
  5. Fujifilm FinePix S1 LCD Screen Replacement: adım 5, 2 resimden 1. Fujifilm FinePix S1 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Disconnect the blue cable set by carefully prying it off with a spudger.
  6. Fujifilm FinePix S1 LCD Screen Replacement: adım 6, 2 resimden 1. Fujifilm FinePix S1 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Use a spudger to lift the LCD screen out of its placement and remove it from the casing.
Sonuç
Brandon Benavente
677 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Sullivan Spring 2016 USF Tampa, Team 3-6, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G6
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,057
