Ana içeriğe geç
Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: adım 1, 3 resimden 1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: adım 1, 3 resimden 2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
  2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 2, 3 resimden 1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 2, 3 resimden 2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 2, 3 resimden 3.
    • Remove the three screws holding the LCD screen in place.
    • Replace with new screen.
  3. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: adım 3, 3 resimden 1. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: adım 3, 3 resimden 2. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement, Flash Mechanism Latch Spring: adım 3, 3 resimden 3.
    • Remove the two screws from underneath the flash mechanism.
    • Remove the two screws placed on the right and left sides of the camera.
  4. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 4, 1 resimden 1.
    • Pry the top of the camera off using the given tool
  5. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 5, 1 resimden 1.
    • Remove two silver plated screw from under the top of the camera, under the flash.
  6. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 6, 1 resimden 1.
    • Remove the rectangular plastic piece.
  7. Fujifilm FinePix S2980 Flash Mechanism Latch Spring Replacement: adım 7, 1 resimden 1.
    • Insert new spring.
    • Replace the plastic piece.
Sonuç
Megan Merlo
78 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-2, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G2
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 1,178
