Ana içeriğe geç
Fujifilm FinePix S4200 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S4200 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Turn the camera off.
    • Turn the camera upside down so that the battery compartment is showing.
  2. Fujifilm FinePix S4200 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the three 4 mm screws from the bottom of the camera with a Phillips #000 screwdriver.
  3. Fujifilm FinePix S4200 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Rotate camera to the side where the speaker ports are located.
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  4. Fujifilm FinePix S4200 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Turn the camera to the opposite side where the HDMI port is located.
    • Remove all five 4 mm screws with a Phillips #000 screwdriver.
  5. Fujifilm FinePix S4200 LCD Screen Replacement: adım 5, 3 resimden 1. Fujifilm FinePix S4200 LCD Screen Replacement: adım 5, 3 resimden 2. Fujifilm FinePix S4200 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Casing is fragile.
    • Utilize the plastic opening tool to pry in between the back casing of the camera from the front casing.
    • Continue this motion around the camera to create a wedge between the front and back casing of the camera.
  6. Fujifilm FinePix S4200 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use force to pull apart the back casing from the camera.
  7. Fujifilm FinePix S4200 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Remove the two 4 mm screws that hold the motherboard and metal plate in place.
  8. Fujifilm FinePix S4200 LCD Screen Replacement: adım 8, 2 resimden 1. Fujifilm FinePix S4200 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Utilize the plastic opening tool to gently lift the LCD screen away from the metal plate.
    • Flip over LCD screen so that the left side of the metal plate is visible.
  9. Fujifilm FinePix S4200 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Rotate the camera vertically so that it is easier to manage.
    • Use a Phillips #000 screwdriver to remove the two 4mm screws that are located on the metal plate under the LCD screen.
  10. Fujifilm FinePix S4200 LCD Screen Replacement: adım 10, 1 resimden 1.
    • Detach the metal plate from the motherboard.
  11. Fujifilm FinePix S4200 LCD Screen Replacement: adım 11, 2 resimden 1. Fujifilm FinePix S4200 LCD Screen Replacement: adım 11, 2 resimden 2.
    • The orange ribbon cable is fragile.
    • Pull back the small black latch connecting the orange ribbon cable to the motherboard.
    • Gently remove the LCD screen from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jackie Acevedo
325 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-4, Bruce Fall 2015 CSU Fullerton, Team 1-4, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S1G4
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Ou peut on trouver cet écran ?
lise.didion - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,484
