Ana içeriğe geç
Fujifilm FinePix S4200 Lens Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S4200 Lens Replacement, Lens: adım 1, 1 resimden 1.
    • Turn off the camera by pushing the ON/OFF switch as shown.
  2. Fujifilm FinePix S4200 Lens Replacement: adım 2, 3 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 2, 3 resimden 2. Fujifilm FinePix S4200 Lens Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #000 screwdriver, remove all of the 4mm screws from the left, right, and bottom of the camera.
  3. Fujifilm FinePix S4200 Lens Replacement: adım 3, 1 resimden 1.
    • Remove casing part pictured by gently pulling up until casing is fully detached.
  4. Fujifilm FinePix S4200 Lens Replacement: adım 4, 3 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 4, 3 resimden 2. Fujifilm FinePix S4200 Lens Replacement: adım 4, 3 resimden 3.
    • Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
    • Use the Phillips #000 to avoid stripping the screws.
  5. Fujifilm FinePix S4200 Lens Replacement: adım 5, 1 resimden 1.
    • Remove orange ribbon cable by gently pulling on the cable until it is detached from the clamping device on the motherboard.
    • Remove the top casing by pulling upwards.
  6. Fujifilm FinePix S4200 Lens Replacement: adım 6, 2 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 6, 2 resimden 2.
    • Carefully remove the LCD screen.
    • Gently pull on orange tab until it is free. This orange strip is susceptible to tearing.
  7. Fujifilm FinePix S4200 Lens Replacement: adım 7, 2 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 7, 2 resimden 2.
    • Remove remaining 4mm screw. Detach metal plate by lifting plate upwards.
    • Use the Phillips #000 screwdriver.
  8. Fujifilm FinePix S4200 Lens Replacement: adım 8, 1 resimden 1.
    • Remove remaining orange tabs on motherboard by gently pulling on all tab until they are free.
    • Caution: Orange strips are susceptible to tearing.
  9. Fujifilm FinePix S4200 Lens Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #000 screwdriver, remove the 4mm screws in the corners of the motherboard.
  10. Fujifilm FinePix S4200 Lens Replacement: adım 10, 1 resimden 1.
    • Use a soldering iron to desolder the five connections shown.
    • Caution: After removing the soldered connections, they must be given ample time to cool before moving to the next step.
  11. Fujifilm FinePix S4200 Lens Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
  12. Fujifilm FinePix S4200 Lens Replacement: adım 12, 2 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 12, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the 4mm screws around the metal plate.
    • Using a Phillips #000 screwdriver, remove the 10mm screws.
  13. Fujifilm FinePix S4200 Lens Replacement: adım 13, 1 resimden 1.
    • Slowly lift up the metal plate and remove it from the camera.
  14. Fujifilm FinePix S4200 Lens Replacement: adım 14, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the 10mm screw.
  15. Fujifilm FinePix S4200 Lens Replacement: adım 15, 2 resimden 1. Fujifilm FinePix S4200 Lens Replacement: adım 15, 2 resimden 2.
    • Remove the inner lens.
    • Caution: Be careful while removing the lens.
  16. Fujifilm FinePix S4200 Lens Replacement: adım 16, 1 resimden 1.
    • Change the broken inner lens with a new inner lens.
    • Reassemble the camera.
Sonuç
Joshua Greer
253 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Harley Fall 2018 IUPUI, Team S1-G5, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S1G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 2,684
