Giriş
To replace the viewfinder you will need to perform the LCD prerequisite. The viewfinder should be replaced if your camera does not focus or your photos lack composition.
Neye ihtiyacın var
Turn the camera off.
Turn the camera upside down so that the battery compartment is showing.
Remove the two 4 mm screws with a Phillips 000 screwdriver under the viewfinder.
2 farklı kişi bu kılavuzu tamamladı.
