Ana içeriğe geç
Fujifilm FinePix S4800 Battery Replacement
  1. Fujifilm FinePix S4800 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Battery Replacement: adım 2, 3 resimden 1. Fujifilm FinePix S4800 Battery Replacement: adım 2, 3 resimden 2. Fujifilm FinePix S4800 Battery Replacement: adım 2, 3 resimden 3.
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Calabrese
584 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S19-G4, Hoffman Spring 2017 USF Tampa, Team S19-G4, Hoffman Spring 2017 üyesi
USFT-HOFFMAN-S17S19G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 3,613
