Ana içeriğe geç
Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: adım 1, 1 resimden 1.
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: adım 2, 1 resimden 1.
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: adım 3, 1 resimden 1.
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Sonuç
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
137 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G1
4 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
should there be an indicator led to show the camera is charing ?
tony smith - Yanıt
should the camera indicate that it is being charged ?
tony smith - Yanıt
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 25
Her zaman: 1,711
