Ana içeriğe geç
Fujifilm FinePix S8200 LCD Screen Replacement
Neye ihtiyacın var
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, Batteries: adım 1, 1 resimden 1.
      • Turn the camera upside down so you can access the battery chamber.
      • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 2, 1 resimden 1.
      • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 3, 1 resimden 1.
      • With the battery chamber open, remove the old batteries.
      • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: adım 4, 3 resimden 1. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: adım 4, 3 resimden 2. Fujifilm FinePix S8200 LCD Screen  Replacement, Rear Housing Cover: adım 4, 3 resimden 3.
      • Remove the 4mm JIS #00 screws from the sides and bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 5, 3 resimden 1. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 5, 3 resimden 2. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 5, 3 resimden 3.
      • Carefully pry away the rear housing cover with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm FinePix S8200 LCD Screen  Replacement: adım 6, 1 resimden 1.
      • Remove the rear housing cover by carefully pulling it away from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: adım 7, 2 resimden 1. Fujifilm FinePix S8200 LCD Screen  Replacement, LCD Screen: adım 7, 2 resimden 2.
      • Fold back the LCD screen with the plastic opening tool.
      • Remove the cable coming from the LCD screen that goes into the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Kelley
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-1, Remmell Winter 2015 USF Tampa, Team 7-1, Remmell Winter 2015 üyesi
USFT-REMMELL-W15S7G1
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 1,626
