Ana içeriğe geç
Fujifilm FinePix S8630 Flash Lid Spring Replacement
Neye ihtiyacın var
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Battery Door: adım 1, 1 resimden 1.
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 2, 1 resimden 1.
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 3, 1 resimden 1.
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      FixBot'a Sor
      Yorum Ekle
    4. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 4, 2 resimden 1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 4, 2 resimden 2.
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    5. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 5, 1 resimden 1.
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 6, 3 resimden 1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 6, 3 resimden 2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 6, 3 resimden 3.
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      FixBot'a Sor
      Yorum Ekle
    7. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 7, 3 resimden 1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 7, 3 resimden 2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 7, 3 resimden 3.
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: adım 8, 2 resimden 1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement, Flash Lid Spring: adım 8, 2 resimden 2.
      • Firmly grasp the flash bulb lid and remove the lid from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 9, 3 resimden 1. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 9, 3 resimden 2. Fujifilm FinePix S8630 Flash Lid Spring  Replacement: adım 9, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the spring and grasp with the tweezers.
      • Pinch and compress the spring to remove it from the camera housing.
      • Slide the lever that was holding the spring out of the camera housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Colton Lancsarics
731 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G2
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 639
