Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If the lens of your camera has stopped moving in and out of the camera body, it's likely that the gears inside are out or alignment or are broken. This guide will show you how to fix that.
Neye ihtiyacın var
The white gear and the black gear closest to the round section of the lens unit are the ones most responsible for the lens's movement.
Using tweezers, you can adjust and replace these gears as needed. The white gear should be flush with the rest of the unit while the black gear should occupy the entirety of its cavity.
Bir Yorum
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
