Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unscrew the six 3.5mm Philips head from the outer casing.
Open the battery chamber and remove the battery.
Pry the front half of the casing from the camera.
Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
Lift the LCD screen out of the camera.
There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
Pry the center casing off the camera. This is best done by separating the top and side sections individually.
Unscrew the two 3.5 mm Phillips head screws in the metal plate.
Peel back the strip of black tape to reveal a red and black wire.
Detach the orange ribbon by gently pulling on it.
Detach the golden ribbon by gently lifting it with the spudger.
The lens should now be free to simply be pushed out of its socket.
The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
Use a Phillips #00 screwdriver to remove four 3.5 mm screws from the corners of the internal plate.
Slide the rectangular plastic frame to the side. You'll find a spring attaches the frame to the rest of the lens casing.
Disconnect the plastic frame from the spring.
Using tweezers, adjust and replace these gears as needed. The white gear should be integrated with the rest of the unit. The black gear should occupy the entirety of its cavity.
Bir Yorum
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
