Ana içeriğe geç
Fujifilm FinePix XP50 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP50 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP50 LCD Screen Replacement: adım 2, 2 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP50 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP50 LCD Screen Replacement, Button: adım 4, 2 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement, Button: adım 4, 2 resimden 2.
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP50 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Pull the three buttons out.
  6. Fujifilm FinePix XP50 LCD Screen Replacement, Front and Back Panel: adım 6, 1 resimden 1.
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  7. Fujifilm FinePix XP50 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  8. Fujifilm FinePix XP50 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  9. Fujifilm FinePix XP50 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  10. Fujifilm FinePix XP50 LCD Screen Replacement: adım 10, 2 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  11. Fujifilm FinePix XP50 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Lift off the front plate.
  12. Fujifilm FinePix XP50 LCD Screen Replacement: adım 12, 3 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement: adım 12, 3 resimden 2. Fujifilm FinePix XP50 LCD Screen Replacement: adım 12, 3 resimden 3.
    • Pry the back plate off with a plastic opening tool
  13. Fujifilm FinePix XP50 LCD Screen Replacement, Back Panel: adım 13, 1 resimden 1.
    • Pry the two latches off using a spudger.
    • It takes some force to pry the latches off, so be careful to not break them.
  14. Fujifilm FinePix XP50 LCD Screen Replacement: adım 14, 3 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement: adım 14, 3 resimden 2. Fujifilm FinePix XP50 LCD Screen Replacement: adım 14, 3 resimden 3.
    • Pry the remaining latches with a plastic opening tool.
    • It's best to start on the opposite side. Then pry off the top and end at the bottom.
    • It may take some force to remove this, but be careful to not break the latches off.
  15. Fujifilm FinePix XP50 LCD Screen Replacement: adım 15, 1 resimden 1.
    • Pull the two halves apart.
    • Reattach the LCD ribbon cable into the slot before closing the halves when reassembling.
  16. Fujifilm FinePix XP50 LCD Screen Replacement: adım 16, 2 resimden 1. Fujifilm FinePix XP50 LCD Screen Replacement: adım 16, 2 resimden 2.
    • Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
    • Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
  17. Fujifilm FinePix XP50 LCD Screen Replacement, LCD Screen: adım 17, 1 resimden 1.
    • Use the plastic opening tool to gently lift the LCD screen up.
Sonuç
Cory Teixeira
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 520
