Ana içeriğe geç
Fujifilm FinePix XP50 Rear Case Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: adım 1, 3 resimden 1. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: adım 1, 3 resimden 2. Fujifilm FinePix XP50 Rear Case Replacement, Rear Case: adım 1, 3 resimden 3.
    • Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
    • Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
  2. Fujifilm FinePix XP50 Rear Case Replacement: adım 2, 3 resimden 1. Fujifilm FinePix XP50 Rear Case Replacement: adım 2, 3 resimden 2. Fujifilm FinePix XP50 Rear Case Replacement: adım 2, 3 resimden 3.
    • Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
    • Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
  3. Fujifilm FinePix XP50 Rear Case Replacement: adım 3, 1 resimden 1.
    • Using Phillips #00 screwdriver, remove the two 3.0 mm screws.
  4. Fujifilm FinePix XP50 Rear Case Replacement: adım 4, 3 resimden 1. Fujifilm FinePix XP50 Rear Case Replacement: adım 4, 3 resimden 2. Fujifilm FinePix XP50 Rear Case Replacement: adım 4, 3 resimden 3.
    • Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
    • Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
    • Once both screws are removed the silver side casing will slide off.
  5. Fujifilm FinePix XP50 Rear Case Replacement: adım 5, 3 resimden 1. Fujifilm FinePix XP50 Rear Case Replacement: adım 5, 3 resimden 2. Fujifilm FinePix XP50 Rear Case Replacement: adım 5, 3 resimden 3.
  6. Fujifilm FinePix XP50 Rear Case Replacement: adım 6, 3 resimden 1. Fujifilm FinePix XP50 Rear Case Replacement: adım 6, 3 resimden 2. Fujifilm FinePix XP50 Rear Case Replacement: adım 6, 3 resimden 3.
    • Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
    • Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
    • The rear panel is now free from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paulo Abalos
122 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 2-4, Grigsby Spring 2015 Baylor, Team 2-4, Grigsby Spring 2015 üyesi
BU-GRIGSBY-S15S2G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
where can I buy the Fujifilm FinePix XP50 Rear Case?
CO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 765
