Ana içeriğe geç
Fujifilm FinePix XP70 Button Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP70 Button Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Button Replacement: adım 2, 2 resimden 1. Fujifilm FinePix XP70 Button Replacement: adım 2, 2 resimden 2.
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Button Replacement: adım 3, 1 resimden 1.
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Button Replacement, Button: adım 4, 2 resimden 1. Fujifilm FinePix XP70 Button Replacement, Button: adım 4, 2 resimden 2.
    • Pry the black button plate off using a plastic opening tool.
    • Buttons can fall out easily.
    • It's easiest to start from the side exposed by an open battery compartment.
    • When putting this plate back on, orientate the buttons as shown to properly fit back into the plate.
  5. Fujifilm FinePix XP70 Button Replacement: adım 5, 1 resimden 1.
    • Pull the three buttons out.
Sonuç
Olivia A
484 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 281
