Ana içeriğe geç
Fujifilm FinePix XP70 Front and Back Panel Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP70 Front and Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Power off the camera.
    • Leaving the camera on while removing presents the risk of electrical shock or permanent data loss.
  2. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 2, 2 resimden 1. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 2, 2 resimden 2.
    • Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
  3. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 3, 1 resimden 1.
    • Pull the orange tab towards the hinge to release the battery.
  4. Fujifilm FinePix XP70 Front and Back Panel Replacement, Front and Back Panel: adım 4, 1 resimden 1.
    • Remove one Phillips screw with a Phillips head 0 screwdriver
    • Remove one hex head screw with a hex 1.3 screwdriver bit.
  5. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 5, 1 resimden 1.
    • Unscrew two 4.0mm long hex head screws with a hex 1.3 screwdriver bit.
  6. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 6, 1 resimden 1.
    • Unscrew five 4.0mm screws with a Phillips head 0 screwdriver
  7. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 7, 1 resimden 1.
    • Pry the black bottom plate off using a plastic opening tool.
    • It is easier to start on the side of the open battery compartment.
  8. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 8, 2 resimden 1. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 8, 2 resimden 2.
    • Pry the front plate off using a plastic opening tool.
    • It's recommended to start at the ridge on the top or bottom side.
  9. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 9, 1 resimden 1.
    • Lift off the front plate.
  10. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 10, 3 resimden 1. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 10, 3 resimden 2. Fujifilm FinePix XP70 Front and Back Panel Replacement: adım 10, 3 resimden 3.
    • Pry the back plate off with a plastic opening tool
Sonuç
Olivia A
484 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G3, Julie Spring 2017 UMass Dartmouth, Team S7-G3, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G3
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Very helpful, do you know if you can buy these parts? I need the back part of the camera.
thank you
jg
Jose Gerardo Hernandez Montiel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 393
