Giriş
A malfunctioning LCD screen, whether it simply won't turn on, dead pixels, or some other issue, is a major inconvenience. Use this guide to get it working properly again.
Neye ihtiyacın var
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Using the H1.3 hex head bit, remove the four screws on the front of the camera.
Once you expose the inside of the camera, use the PH000 Phillips head bit and remove the four screws as shown.
Carefully remove the tape binding the screen to the camera.
