Ana içeriğe geç
Fujifilm FinePix XP80 Lens Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP80 Lens Replacement, Battery: adım 1, 3 resimden 1. Fujifilm FinePix XP80 Lens Replacement, Battery: adım 1, 3 resimden 2. Fujifilm FinePix XP80 Lens Replacement, Battery: adım 1, 3 resimden 3.
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Lens Replacement: adım 2, 1 resimden 1.
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Lens Replacement, Exterior Case: adım 3, 1 resimden 1.
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Lens Replacement: adım 4, 1 resimden 1.
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Lens Replacement: adım 5, 1 resimden 1.
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Lens Replacement: adım 6, 1 resimden 1.
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Lens Replacement: adım 7, 1 resimden 1.
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Lens Replacement: adım 8, 1 resimden 1.
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Lens Replacement: adım 9, 2 resimden 1. Fujifilm FinePix XP80 Lens Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Lens Replacement, Interior Case: adım 10, 1 resimden 1.
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Lens Replacement: adım 11, 1 resimden 1.
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Lens Replacement: adım 12, 1 resimden 1.
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Lens Replacement: adım 13, 3 resimden 1. Fujifilm FinePix XP80 Lens Replacement: adım 13, 3 resimden 2. Fujifilm FinePix XP80 Lens Replacement: adım 13, 3 resimden 3.
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Lens Replacement: adım 14, 1 resimden 1.
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Lens Replacement, Lens: adım 15, 1 resimden 1.
    • Using a plastic opening tool, remove the entire lens housing.
    • Install the new lens and housing (it is replaced as a single unit).
Sonuç
Amanda Lewis
317 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G3
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 1,546
