Ana içeriğe geç
Fujifilm FinePix Z1 Battery Access Door Spring Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix Z1 Battery Access Door Spring Replacement, Battery Access Door Spring: adım 1, 1 resimden 1.
    • Locate the Battery Access Door on the bottom of the camera.
    • Ensure that the door has no obvious cracks or damage.
    • See if the door slides out and opens completely.
  2. Fujifilm FinePix Z1 Battery Access Door Spring Replacement: adım 2, 3 resimden 1. Fujifilm FinePix Z1 Battery Access Door Spring Replacement: adım 2, 3 resimden 2. Fujifilm FinePix Z1 Battery Access Door Spring Replacement: adım 2, 3 resimden 3.
    • Apply pressure to the door and pop the component out.
    • Using a H0.7 bit, push the rod out of the door to remove it from the camera.
    • Adjust or replace the spring.
Sonuç
Carra
533 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 143
