Ana içeriğe geç
Fujifilm FinePix Z1 Battery Replacement
  1. Fujifilm FinePix Z1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the battery on the display screen of the camera is charged. If it is not fully charged, plug into charger and turn the camera on.
    • If the battery image on the display screen does not show then you will need to check the battery.
  2. Fujifilm FinePix Z1 Battery Replacement: adım 2, 1 resimden 1.
    • Turn the camera to the bottom and find the battery access door on the left side.
  3. Fujifilm FinePix Z1 Battery Replacement: adım 3, 2 resimden 1. Fujifilm FinePix Z1 Battery Replacement: adım 3, 2 resimden 2.
    • Open the battery access door by pushing down and up on the spring-hinged door.
    • Check that there is no obvious damage or reason for a faulty battery.
  4. Fujifilm FinePix Z1 Battery Replacement: adım 4, 1 resimden 1.
    • Push the yellow tab to eject the battery.
  5. Fujifilm FinePix Z1 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery and replace with a new one.
Sonuç
Carra
533 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 677
