Ana içeriğe geç
Fujifilm FinePix Z1 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: adım 2, 3 resimden 1. Fujifilm FinePix Z1 LCD Screen Replacement: adım 2, 3 resimden 2. Fujifilm FinePix Z1 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: adım 3, 2 resimden 1. Fujifilm FinePix Z1 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: adım 4, 3 resimden 1. Fujifilm FinePix Z1 LCD Screen Replacement: adım 4, 3 resimden 2. Fujifilm FinePix Z1 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Sonuç
Carra
533 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S2-G4, Johnson Spring 2018 Baylor, Team S2-G4, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S2G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 277
