Ana içeriğe geç
Fujifilm FinePix Z5 LCD Screen Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Fujifilm FinePix Z5 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Remove the two screws on the right side of the camera and the two screws on the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 LCD Screen Replacement: adım 2, 2 resimden 1. Fujifilm FinePix Z5 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the three screws from the bottom of the camera.
    • You need a three-prong screw driver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 LCD Screen Replacement: adım 3, 3 resimden 1. Fujifilm FinePix Z5 LCD Screen Replacement: adım 3, 3 resimden 2. Fujifilm FinePix Z5 LCD Screen Replacement: adım 3, 3 resimden 3.
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 LCD Screen Replacement: adım 4, 2 resimden 1. Fujifilm FinePix Z5 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Pull the LCD screen to the left slightly, lift it and flip it open to the right.
    • There is also a ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 LCD Screen Replacement: adım 5, 2 resimden 1. Fujifilm FinePix Z5 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Using a small flat head screw driver, flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Using your index finger, guide the cable of the new screen into place. Lock it in by pushing the black lever back down.
Sonuç
Kyle Kaczmar
14 İtibar
1 Kılavuz yazıldı
Ekip
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 1,226
