Ana içeriğe geç
Fujifilm FinePix Z5 Optical Lens Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: adım 1, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: adım 1, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement, Optical Lens: adım 1, 3 resimden 3.
    • Remove the two screws from the right side of the camera and the two screws from the left side.
    • Use a small #00 Phillips flat head screwdriver.
    • Keep all the screws in a container and the two different types separate.
  2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 2, 1 resimden 1.
    • Remove the three screws from the bottom of the camera.
    • Use a three-prong screwdriver for two of the three screws; keep these screws separate.
  3. Fujifilm FinePix Z5 Optical Lens Replacement: adım 3, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 3, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 3, 3 resimden 3.
    • Remove the back by carefully flipping it open to the right side.
    • There will be a ribbon cable attaching the front panel to the motherboard, be sure not to tear this.
  4. Fujifilm FinePix Z5 Optical Lens Replacement: adım 4, 2 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 4, 2 resimden 2.
    • Pull the LCD screen to the left slightly, then lift and flip it open to the right.
    • There is an orange ribbon cable attaching the LCD screen to the motherboard, be careful not to tear it.
  5. Fujifilm FinePix Z5 Optical Lens Replacement: adım 5, 2 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 5, 2 resimden 2.
    • Using a plastic opening tool to flip open the black lever to release the ribbon cable.
    • Gently slide the cable out of the lock; the LCD screen is now free to be removed.
  6. Fujifilm FinePix Z5 Optical Lens Replacement: adım 6, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 6, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 6, 3 resimden 3.
    • Remove the two screws that are holding the silver paneling on.
    • There is a gold foil which will tear upon removal of the silver paneling, this is normal.
    • Remove the screw anchoring the motherboard on the right.
  7. Fujifilm FinePix Z5 Optical Lens Replacement: adım 7, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 7, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 7, 3 resimden 3.
    • Detach the two ribbon cables on the left side of the camera the same way the LCD cable was detached.
    • Detach the gold ribbon cable on the top middle of the camera as well.
  8. Fujifilm FinePix Z5 Optical Lens Replacement: adım 8, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 8, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 8, 3 resimden 3.
    • Hold wires on the left with an index finger, to keep them out of the way.
    • Carefully wiggle out the motherboard. The flash and the speaker will come with it.
    • Make sure you have a motherboard that includes the flash and the speaker; these items are both soldered onto the motherboard.
  9. Fujifilm FinePix Z5 Optical Lens Replacement: adım 9, 3 resimden 1. Fujifilm FinePix Z5 Optical Lens Replacement: adım 9, 3 resimden 2. Fujifilm FinePix Z5 Optical Lens Replacement: adım 9, 3 resimden 3.
    • Lift the lens off of the camera base (there is nothing anchoring it down).
Sonuç
Inga Direktorchuk
72 İtibar
2 adet Kılavuz yazıldı
Ekip
James Madison, Team 3-4, Klein Spring 2012 James Madison, Team 3-4, Klein Spring 2012 üyesi
JMU-KLEIN-S12S3G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 798
